Gen Render Elements VRay Property
  • Gen Render Elements VRay Property
    I have a backdrop I need to add to my scene as a geometry sphere, not an environment map. I have given the sphere a vraylightmtl, but I do not want it to appear in the vrayselfillumination render element. I have disabled "Gen Render Elements" in the vray properties for the sphere, but it is still visible. Is that a bug or am I misunderstanding what this option is for?
    I realise I could split them into passes, but I would like to find a solution that allows me to render the background with the foreground elements in 1 pass.
    Any ideas on a possible workaround welcome...
    Cheers,
    Olly
    Set V-Ray class properties en masse with the VMC script
    Follow me for script updates: @ollyspolys
    Hi Olly,
    I would suggest to divide the unwanted data from the Self Illumination element in post. For that process you can use the multimatte element to generate a mask for the env. sphere. Here is one example:
Name:	2016-03-25 09_40_08}.png
    Generate Render elements doesn't affect all V-Ray render elements so you have to consider another approach.
    Tashko Zashev | chaos.com
      Thanks Tashko.
      That is how would normally do it - I just saw that option and wondered if that is what is was for.
      Could you add an explanation of the option and its limitations to the help doc?
        Yes, forwarded to our technical writers team
