Brute Force Light Cache issue
  • Brute Force Light Cache issue
    When using BF/LC, my V-Ray Frame Buffer builds the Light Cache and then begins to render with no issues. I can see the overall image brightness fairly well as it renders.
    However, my client is having an issue where we have the same settings, but after the initial LC begins to build, the Frame Buffer goes black until its rendered out. What is happening?
    Thanks.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    Are you sure you are both using the same version of V-Ray? There is a prepass that happened on the second image and it caused the light cache preview to be overwritten.
      Both images are with 3.3.0.03.
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        The only thing that I can think of is if you have a fastsss2 material in the scene - it switches from prepass-based to raytraced mode in newer builds.
          No, just standard VrayMtl in the scene. The issue only happens with BF/LC in Adaptive mode. If we switch to IR/LC Adaptive, or use BF/LC in Progressive, it doesn't happen.
          David Anderson
          Software:
          Windows 10 Pro
          Hardware:
          Puget Systems
          TRX40 EATX
          128GB RAM
            Open the vraylog.txt file and search for a line that says "Registering reflection interpolation map..." or "Registering refraction interpolation map..." or "Registering SSS prepass illumination map..." - do you find anything? Or alternatively, just post the two log files here from both machines so that I can compare them.
