How would one go about creating an actual carbon fiber shader?
  • How would one go about creating an actual carbon fiber shader?
    I mean a real one - not just a lit diffuse texture and shiny-shiny. Is there a way of achieving that through shading only? If so how would you go about it? One would need the bumpyness, reacting to light the right way, aswell as a clearcoat.
    Software:
    Windows 7 Ultimate x64 SP1
    3ds Max 2016 SP4
    V-Ray Adv 3.60.04
    Hardware:
    64GB RAM
    DxDiag
    you need a carbon fiber texture pattern, and matching anisotropy direction pattern, then use that as a base for your carpaint material with glossy anisotropy with ggx, and layer a reflective coat overtop.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Like Dmitry says, Anistrophy map is the technique to use combined with normal map and with clear coat on top.
      Maxscript made easy....
      davewortley.wordpress.com
      Follow me here:
      facebook.com/MaxMadeEasy
      If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
        Some time ago I actually did a short tutorial on carbon fiber material:
        https://resources.squid.io/library-t.../carbon-fiber/
        It is not perfect, as the shader had to conform to turbosquid guidelines, but I think is a pretty good base
          Interesting information, didn't think about the aniso technique, but it makes total sense. Thanks for the pointers!
          Software:
          3ds Max 2016 SP4
          V-Ray Adv 3.60.04
          Hardware:
          64GB RAM
          DxDiag
            Are those maps available somewhere to buy/download?
            Software:
            3ds Max 2016 SP4
            V-Ray Adv 3.60.04
            Hardware:
            64GB RAM
            DxDiag
              Here are the basic maps I used
              CF_set.zip
                Thanks, much appreciated.
                Software:
                3ds Max 2016 SP4
                V-Ray Adv 3.60.04
                Hardware:
                64GB RAM
                DxDiag
