Shadows controlled from material?
  • Shadows controlled from material?
    I have a scene where the light is hitting a white carpet and causing objects near a wall to have upward shadows which looks quite odd. In controlling those, would be be more about the reflectivity of the carpet material, or "affect reflections" of the light? or both?
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    You can deactivate the generate GI checkbox in the v-ray object properties, or turn down it's multiplier.
    But than your image will look less physical.
    What is your white value 255*255*255 would be to high.
    Try something like 220*220*220 if that is the chase.
    German guy, sorry for my English.
      That would be for the carpet, correct? It's actually not a pure white carpet, but rather a light beige color. Let me play around with that a little more. Thanks.
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        Yes.
        If you work on a Still, I'd render the whole image without touching the generate GI option.
        After that I'd render the area in which the issue appears with generate GI tured off and comp it together in ps.
        This will at least keep the physicallyness of the rest of the image.
          Yes. Exactly. Good thoughts. Thanks!
          David Anderson
          Software:
          Windows 10 Pro
          Hardware:
          Puget Systems
          TRX40 EATX
          128GB RAM
