Is it possible to drive vray environment fog with particles ?
  • Is it possible to drive vray environment fog with particles ?
    Is it possible to use particle flow particle position as a gizmo reference for vray envfog ?
    I was hoping to place a series of particles in 3d space and have vrayenv fog create cloud puffs at the particle.
    Adding particle flow as a gizmo doesn't work.
    Regards
    Steve
    My Portfolio
    I haven't tried, but two things come to mind:
    1. This script:
    http://www.scriptspot.com/bobo/mxs5/...ingObjects.htm
    Pretty old but should still do the trick still.
    2. A mesher compound object, pick the pflow with the mesher and then pick the mesher in the env fog window.
    Rens Heeren
    Generalist
    WEBSITE - IMDB - LINKEDIN - OSL SHADERS
      Thanks. I think the mesher compound or even using blob mesh might work.
      Regards
      Steve
      My Portfolio
        blob mesh would be preferable to any method that copies objets to particles, since, unless its changed, intersecting objects/flipped faces etc, cause artifacts in the env fog when used as gizmos.
          Cheers. I'm using blob mesh
          Regards
          Steve
          My Portfolio
