Mesh Edges
  • Mesh Edges
    Often, I get these mesh edges when using displacement. How do I get around them? They are hidden and I think I am using 2d displacement.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Yep, 2d displacement. 3D does its own choppery.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      What happened to Paul's trick with RailClone for this stuff or is displacement faster for you?
      Kind Regards,
      Morne
        You know, I tried, but I forgot how to do it I tried to use the RC siding for my other project, but it was doing some strange things, so I bailed and went with the tried and true.
        I still think Railclone needs some built-in things, like this, which is so common.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I think I've had similar issues when my geometry was messy, ie. from extruded splines. Did you check your geometry for any issues?
            It's just an extruded spline, like you said.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              OK, then try to retopologize it to make it all quads, cut here, slice there, it should work. Extruding splines usually results in large polygons with random bad topology.
                Maybe your texture has a bit of noise on the edges or doesn't tile perfectly? Does 'keep continuity" seem to do anything for you?
                  the displacement is just a gradient.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Well, so much for that theory. Interested to see how it pans out though.
                      I just got an email with a kitchen cabinetry workflow in rail clone, hopefully siding and roofing is next!
                        Yes, I saw that. I am not sure it is in the library, is it? He is showing how to build the kitchen, but what I watched, it wasn't from a library.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Making a siding railclone takes like 5 minutes at best. I don't understand why it should be in a library but I've made one just now. I've attached it to this post (MAX 2016, centimeters). They only thing you need to do is have a clipping spline and an aligned RC. But you can do that even automatically with this script:
                          http://forum.itoosoft.com/index.php?...13321#msg13321
                          Cladding.zip
                          A.
                          www.digitaltwins.be
                            The cleaning corners is what I need to figure out.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              Depends on how the corners are detailed, you have a lot of different ways.
                              https://www.google.com/search?q=clad...qix5Mb_IoiM%3A
                              A.
                              www.digitaltwins.be
