Blend to a Seethrough material using VRayBlend, or another proper way
  • Blend to a Seethrough material using VRayBlend, or another proper way
    I need to use a map to blend to a seethrough, invisible material. I haven't found a way to do that in VRayBlend material. Using a standard blend material does work in the beauty, but messes up the render elements, and I know is not the proper way to do it. What is the right way to do that?
    Thanks
    Hristo Velev
    MD/FX Lead, Bottleship VFX
    Sofia, Bulgaria
    if you put your material in vray blend coat, and leave the base as nothing - you should be able to blend the same way.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Awesome, looks like that works! Thanks
      Hristo Velev
      Sofia, Bulgaria
        Originally posted by glacierise View Post
        Thanks
        1. Create a VrayBlendMTL with a Vraymaterial in the base layer.
        2. The baselayer material has a vraycolor map in the opacity slot set to black
        3. Create your vraymaterial that you need to see in the coat layer and the map you want to use as a mask in the blend amount.
        4. ???
        5. Profit
        Edit: woops; apparently I took too long to answer. And the base material with black in the opacity slot isn't necessary apparently
        A.
        www.digitaltwins.be
