Animation settings BF+LC
  • Animation settings BF+LC
    I will go with my 1st little animation with BF+LC (an exterior, a simple sequence shot, about 1500 frames...)
    BTW, the default settings are so great that I will not change anything... Will try to use denoiser (for the 1st time)
    My questions are :
    - about LC,how can I estimate how many subdiv. I will need ?
    - about Denoiser, if I just want to have my RGB element and RGB denoised (without noiseLevel,defocusAmount,...in fact without any render element from Denoiser), what are the settings ?
    Thanks in advance
    (Sorry for my bad english)
    Hover over the LC values, then read the Tooltips. 3000 is good for animation. Retrace 8 is good for animation
    Kind Regards,
    Morne
      Thanks !! 2 month ago, I was still working with vray 2.5 ! so I have some settings and tricks to learn
      Have you ever used Denoiser for animation ?
        ok then, this is done !
        And I have to say that... Vray 3.4 is really really great !! Thanks Chaos !
        By the way, I had a weird problem with Vray Denoiser. I have some artefacts only with proxy that forcing me to not use Vray Denoiser frames.
        Proxy disappears on certain frames.... Don't know why
          By the way, I had a weird problem with Vray Denoiser. I have some artefacts only with proxy that forcing me to not use Vray Denoiser frames.Proxy disappears on certain frames.... Don't know why
          That's weird. Is it a single particular proxy that exhibits this behavior? If so, does the same issue occur in a new scene with the same proxy in it?
          Miroslav Ivanov
          Chaos Cosmos
            It's really strange because it's about all the proxy in this scene (trees, stones, etc) but all is good with RGB color
              I couldn't reproduce the issue here. Can you share the scene to support@chaosgroup.com so we can see what is going on (mention this forum thread in the message)?
              Miroslav Ivanov
              Chaos Cosmos
                Thanks !
                not really (NDA) but I will try to purge this scene (just keep all Vrayproxy and some other stuf), pre cal a new LC and if I've got the same problem, I will send you the scene.
                  A simplified, stripped down version will also work as long as the issue can be reproduced. Thanks rikou.
                  Miroslav Ivanov
                  Chaos Cosmos
                    Thanks to you !
                    I tried to reproduce the issue but now all is ok (with the same LC because I don't think that it was something to do with LC)
                    The fact is that I don't render this scene... I sent it to a external render farm
                    Anyway, I will send you a part of the movie, you will see what I mean
                      Hello,
                      I have the same problem today
                      Any news about that ?
                      Thanks.
