Probabilistic lights - More Detailed Explanation
  • Probabilistic lights - More Detailed Explanation
    Hello,
    i was reading more details about probabilistic lights in V-ray 3.0, here in the following link: https://docs.chaosgroup.com/display/...lobal+Switches
    but we need more detailed explanation about how it works?
    -when on: does it reduce the flickering in animation renders ? or does it increase the risk ?
    -does the vray denoiser works with the probabilistic lights?
    -should we have more than one vray light in the scene to take effect?
    -does it take effect with the VRAY SUN ?
    attahced is 2 images of 2 same renders; one with probabilistic lights and other without
    can't see any difference? Click image for larger version
    PC Specs: CPU i9-14900K - GPU RTX 4090 - RAM 192GB 5200MHz - MB Asus ROG Maximus Dark Hero
    if your scene looks exactly like the example image - ie: hundreds of very similar lights in an enclosed space, and they are giving you noise issues that are hard to clean up then use it. if your scene is not that exact setup, dont.
      Yes, I would say turn it off unless you've got at least tens or hundreds of lights in your scene. It also seems to create problems with IES lights. At least it did for me some time ago, maybe it's fixed now.
      Aleksandar Mitov
      www.renarvisuals.com
      office@renarvisuals.com
      AMD Ryzen 9 9950X 16-core
      96GB DDR5
      GeForce RTX 3090 24GB + GPU Driver 566.14
        For the next SP, V-Ray 3.5, the probabilistic lights will work better and hopefully there won't be any need to adjust them.
