dual processor problem
  • dual processor problem
    Hi!
    I have problem with vray and dual Xeon processor configuration. When I render the scene with vray it shows me only two buckets. HT is enabled and in device manager under windows (XP) I see 4 processors, so windows recognise them. What should I do in order to enable max and vray to use dual technology?
    Thanks in advance....
    Theo
    You probably don't have checked ON the multi-threading option in preferences.
    Go to Customize/Preferences/Render-> and there you will find thi s option ( bottom left )
    jan
      Hi!
      That is the wierdest thing. I have this option checked...
      Any suggestion what to do?
      Thanks in advance.
        you can turn on HT in device manager? thought it could only be turned on in the BIOS
          I think he meant that he can verify that he has 4 processors via Device Manager.
          Surreal Structures
          http://surrealstructures.com/blog
            Correct...
            In device manager (under processor) I see that I have "4" processors...
            So, the windows recognised both processors and the HT.
            I only don't know why vray shows only two buckets instead of four...and the option of HT inside max is enabled....
            Anybody?
            Thanks in advance.
