Anyone know how to access the multiplier for hdri material in the curve editor? I can only see 4 options for it and none are the multiplier.
vray hdri and curve editor
For Vray the multiplier should be a spinner in the material editor when you copied HDRI from the environment slot (I forget which order tho it should be there.) I hope that answers your question.
Tricky. I wonder if you would need to load up splutterfish's hdri loader within vray in order to do that.
Yes it does, splutterfish hdri loared works just fine. As I only got the basic version of Vray, this tool is soo usefull, and it works well with the sphere technique over the environment one, wich is way more versatileAlain Blanchette
www.pixistudio.com
