As the subject says, do adaptive lights work with animation? Or is the evaluation per-frame and thus would lead to flickering?
VRay 3.5 Adaptive Lights - suitable for animation?
Originally posted by duke2 View PostAs the subject says, do adaptive lights work with animation? Or is the evaluation per-frame and thus would lead to flickering?
I have done some animation using Adaptive Lights and have seen no problems like this as of yet...
-AlanLast edited by Alan Iglesias; 09-02-2017, 06:50 PM.
I've rendered a 5 minute full animation going from interior to exterior with a huge amount of plane lights and HDRI with this algorithm, no problems whatsoever, with the default (BF/LC) and LC on 3000 and 8.0 retrace.
Originally posted by Vizioen View Postwith the default (BF/LC) and LC on 3000 and 8.0 retrace.
Thanks.Nicolas Caplat
www.intangibles.fr
Originally posted by NicoC View PostInteresting .. I thought Retrace was useful only with using IrrMap as primary engine, bringing some BF locally. When we use IrrMap (less and less often), we tend to keep Retrace pretty low, between 1 and 2. You set it at 8 for any particular reason ?
Thanks.And if you read the tooltips displayed in the rendersettings you'll see that suggestion.
http://forums.chaosgroup.com/showthr...tion-rendering
Originally posted by mediarobotics View Posti think Adaptive Lights option lead to a non-realism animation render, it is better to render still images with it ? what do you think?
VladoI only act like I know everything, Rogers.
It is optional in case you come across issues that we didn't find during the beta, just as a fail-safe. It works fine both for indoor and outdoor scenes. There should be no need to remove it based on scene type.
