Originally posted by jasonhuang1115
View Post
Brute force Test Very slow :(
Lele
emanuele.lecchi@chaos.com
Disclaimer:
Originally posted by ^Lele^ View PostIt's entirely my fault.
I spent a wee bit of time with hundreds of VRScans, profiling their measured response in RGB in a way which returned the exact albedo value (as Normal fraction, or 0.0-1.0, or %, as you wish to read it) at each incidence angle (more precisely, i sampled it at 10 bit, or 1024 samples across the 90 degree angles), and then we all got lost into other stuff, and I personally never came around to preparing the post.Last edited by Ihno; 21-06-2017, 07:28 AM.German guy, sorry for my English.
Guys...how would that translate in vray setups? I mean I often had problems with noise popping up where it shouldn't because I often had scenes with dark materials that I needed to be even darker. Also they had lights with mult 1.0 so my scenes had cameras with shutter speed and f number of like 2, and 4. In the end you get the same result but I guess those low light settings messed up some thresholds so vray couldn't clear the noise even on high settings. I know that progressive render cleared certain areas of my scenes but the problematic areas just continued to have a lot of weird noise. I sent the scene to chaos but they too said they don't know what to do really.
So my question is what multipliers for sun/sky do you use? If vray sky is in light dome texture.www.hrvojedesign.com
Sometimes I get to 1/1/1 - 3/3/3 in rgb, then I usually just use color correction to make them even darker, since around these values I also loose any color, it's either 0 or 255 in saturation.
With sun 1.0 do you guys use values of 10-30 for dome light with vraysky?www.hrvojedesign.com
start here (terrestial albedo section):
https://en.m.wikipedia.org/wiki/Albedo
you can find tables for more materials online.Marcin Piotrowski
youtube
But that's for developers. As I'm sure you understood, I meant how does that translate in terms of default settings. By now vray has come out of its developing stage. I know that many scenes need special tweaks, but there should be a guide, as you get with every tool you buy , how to start. What are the main light intensities one should use to get a daylight scene? Or...if should we keep the camera in shutter speed range of about 100, f number 8 and then adjust our lights to match this? Should we still use rgb values of about 128 for our whites or is it ok to use say 220 now?
I've came across few bugs if you use low camera values...also low light mult values.
I often read vray docs and they are helpful but sometimes they miss these basic settings - how to start. (unless I missed something?)
I know we were in an era of discovery and development but now I feel we are out of that and we should start using the research results that came out of it.www.hrvojedesign.com
Originally posted by Crayox13 View PostBut that's for developers.
so it should be logical that you should follow real life while creating shaders. your dark ones reflect 10 times less photons that darkest material on this planet (more or less). vray will see them as almost black holes sucking in light.
Marcin Piotrowski
youtube
