Brute force Test Very slow :(
  • #61
    yes thats pretty much it Piotrus, the curve is a little more filmic rather than the traditional s-curve, sometimes i play a little with contrast and bring a little color to the blacks so they dont look grayscale if you knwo what i mean
    Martin
    http://www.pixelbox.cz
    • #62
      just drop your black point on a curve a bit lower. the point of PBR shaders is no more guessing game like "maybe 5 would look better". the rest is postproduction.
      Marcin Piotrowski
      youtube
      CGI OCIO config 04
      • #63
        Cool will try that cheers!
        Martin
        • #64
          Originally posted by ^Lele^ View Post
          Mandate number 1 of the "new" method is a settings reset, and *without changing a thing* setting the LC up as instructed.
          So do that first, make sure you don't calculate an AO on top of a BF render that way (that was put there a decade ago to hide the mess of the IRMap, it's not only useless, but detrimental to render with BF/LC), stay in LWF (again, Optimised Defaults!), and recalibrate your shaders and lights to match the real world counterparts at best you can: look up light fixture specs, and copy them on your lights,find read albedo tables for material classes (you won't for specific ones!) and try and aim for a diffuse+reflection in the shaders to be in that ballpark, often a *lot* lower than people realise (f.e. most glasses have 7-12% max total reflectivity.).
          When you say most glass only has 7% to 12% reflectivity, are you talking about, on a scale of 0 (black) to 255 (white), that the colour in the Reflection slot should be about 40 or so, aka a dark grey?
          • #65
            yes, and regardless of fresnel.
            Lele
            emanuele.lecchi@chaos.com
            Disclaimer:
            • #66
              That's super surprising to me. I've always used 255 in reflectivity for glass (and IOR of +/-1.5) and obtained realistic results that way. I was also under the impression that a physical workflow required 255 reflectivity in all cases, with glossiness/roughness and IOR being used to modulate not just the blurriness but the intensity of the reflection.
              Check my blog
              • #67
                it would be total refl, diffuse and spec.
                Marcin Piotrowski
                youtube
                CGI OCIO config 04
                • #68
                  and a lot of light would just go through
                  Marcin Piotrowski
                  youtube
                  CGI OCIO config 04
