So from some preliminary tests, the Ryzen 7 1800X works pretty well, it's a little more than 2x faster than my current i7-4771 workstation.
I did have to use the Ryzen Master tool to peg the CPU clock speed though, otherwise the clock speed of the cores went up and down and CPU usage hovered around 97%-99% all the time when rendering with V-Ray, even though the CPU temperature was quite low and Windows power profile was set to "High Performance". It seems to me like some kind of glitch with Ryzen's power savings/clock boost logic.
Once I fixed the clock speeds to 3700 MHz for all cores in Ryzen Master, CPU load was at 100% when rendering and it gave me 3%-5% render time reduction compared to the defaults.
I also timed other CPU benchmarks, it's interesting that the speed-up factor compared to my i7 was not consistent. For example, Cinebench was the same as V-Ray with 2.15x render time reduction, but the Corona Benchmark was only 1.97x.
Scenes that I tested for V-Ray were the two scenes from VRayBench and ArchInteriors'37, scene 6. Benchmarks ran 3 times and I took the average values.
