Hi guys,
I have several objects (materials) that reflect my background too much. I turned off the dome reflection and put my vraysky with output map in the environment refl/refr override. Then I put the same (not instanced) map in my materials that I would like to reflect less of the environment with lower output values. I put this map in their environment, and even tried using 0 but it doesn't seam to work. Also I tried vray override material with similar settings but reflection remains the same. What is the correct way?
