reducing/removing moire effects
  • reducing/removing moire effects
    A recent render of a building has vary fine horizontal cladding details which are causing a slight moire effect.
    What do people generally do to reduce or, hopefully, remove this effect?
    I am now trying simple two level aa with random ticked, set to 1,6. My AA filter is now set to area at 1.5
    Any other tips/suggestions? The texture is not bitmap based, but a very fine gradient procedral map.
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    Yeah.. the problem is that you probably need to set your min up more then you max. Here are some suggestions. First use the mitchel filter... generally better.
    try adaptive at 0,2
    try two way at 2,4
    try adaptive at 1,2
    if all else fails try fixed at 3 then 4 (last resort)
