Hello guys....could someone please help me get a marble flooring like this....http://www.chaoticdimension.com/foru...marble.....you see, i am working on a shopping mall project and have a marble flooring which I need to be reflective and can't find the right settings in the forum....it would also help if someone could suggest a way of doing this with very low render times as this is supposed to be for an animation and I am a little tight on deadlines ....thx in advance guys.
Marble flooring....Please help!!
hey percy...thx for the response mate....actually, I do not know where to put up my image on....all I can tell you is that I put a marble bitmap in the diffuse slot, put the reflect to a dark grey, Glossiness= 0.95, Subdivs=30, and turn on Use Interpolation......all other settings remain unchanged...also, how do I stop the floor from reflecting the environment...since I find that when I change the Reflecy color to a light grey....the diffuse map starts losing it's strength and becomes transparent....I was pretty impressed with floor shown in the link given and needed some settings to get one like that please.....thx again
cheers
FarhanShow me how to do that...please!!!
well keep in mind, vray is an accurate raytracer. If your looking at your floor at an extreme incidence angle (camera is really close to the floor) then your going to get alot of reflections, and that takes away from the diffuse. Thats normal. Make sure your reflection ior is set to standard 1.6. Then adjust your reflect color as necessary. Remember the the older the floor, the less reflective its going to look.
