aghhhh, prob with texture & alpha maps on 2d planes
  • aghhhh, prob with texture & alpha maps on 2d planes
    hi,
    having a weird prob, I have a 2D plane that has texture and alpha maps mapped ot it, as seen on the image I can see the top edge of the plane,
    I am using Max Std material but I have had some probs tih coloured splotches in the renders so i need to use the Vray mat, just to confirm I put the alpha in the Refract slot (1.09) and se the ior to 1?
    I know the advantages of using 1.46 but I need this out the door this week and then I will install the upgrade when I have some downtime.
    any help is appreciated,
    Thanks,
    Tom
    Accept that some days you are the pigeon, and some days you are the statue.
    I spoke too soon, the error has appeared again, will post the rendered image of the scene to illustrate, my prob is still there
      Try setting your tilling to a little less than 1 for V . This looks like an old Max issue that I believe only happens with Pyramidal Filtering.
      --Jon
        yep Trapezium that did the trick, I wasnt looking at it as the image repeating itself I immediately thought it was a shadow/edge issue,
        thanks for the tip
        Tom
          No problem Yeah, I think it's just something like the blurred pixels of the repeated image like you said.
          --Jon
            Just unchecking "tile" should fix it too, without changing the mapping
            Eric Boer
            Dev
