Removing main workstation from DR rendering Vray 1.46
  • Removing main workstation from DR rendering Vray 1.46
    Is it possible to remove the main workstation from rendering when using DR in Vray 1.46? I just want my slaves to render and not tie up the processors on my main workstation.
    Any reply would be great as this is pretty urgent
    Cheers,
    Craig
    At present, the client machine always takes part in the DR process.
      maybe it works queuing the render to another box with backburner?
      Marc Lorenz
      ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
      www.marclorenz.com
      www.facebook.com/marclorenzvisualization
        I dont think you can send a DR job from backburner
          why not? backburner shouldn't notice.
          if i wasn't that lazy i'd try it out.
          Marc Lorenz
          www.marclorenz.com
            i asked this question only a few days ago...
            you cant remove the client from DR but ticking the option of 'low thread priority' will reduce the load on you workstation...
              You can use the low thread priority or if you have a dual CPU machine you can set the affinity through the task manager for 3dsmax to use only 1 CPU.
              -dave
              Cheers,
              -dave
              ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
