Vrayshadows looking strange...
  • Vrayshadows looking strange...
    I'm doing an interior shot and wanted to do a multi-element pass to play with reflections in comp, all my passes are fine except vrayshadows which looks like the attached image. I've deleted the render element and re-loaded it, shut down and re-opened the file just in case it was a hiccup in the software but it changes nothing. Anyone have any ideas?
    After some playing around I've discovered the problem is coming front the main vray plane at the front door, I've replaced it with a new one but to no avail. I've tried moving the plane inside the hall and playing with shadow bias and sampling rate but nothing changes.
      Can someone test something for me please? I started a new file to see if something was corrupt, made an 'L' shaped box with a vray plane light at one open end and a vray cam in the other and I'm still getting weird jagged Vrayshadows. I can't see anything wrong in my light setup.
        This might be a wild guess but does the problem go away if you use "Full lights evaluation" instead of "Adaptive lights" in Global Switches? You may have to switch to Advanced or Expert settings to see the dropdown list.
        Aleksandar Mitov
        www.renarvisuals.com
        office@renarvisuals.com
        AMD Ryzen 9 9950X 16-core
        96GB DDR5
          YES!!! Thanks Alex, you're a star I'd never have thought of looking there, strange it would cause an issue in the test above that only had a single light in it though.
            Good to hear. Actually, there were a couple of threads around here lately about issues with the shadows where the problem turned out to be the use of Adaptive Lights. So maybe my guess was not so far fetched after all.
            Aleksandar Mitov
            96GB DDR5
              This issue is fixed for the next update. If you want a fixed build, email me to vlado@chaosgroup.com
                Thanks Vlado, I've sent you an e-mail.
