Hey,
I know this is not the right forum because this is a "max-only-problem" - but I really need help
I?ve got the following situation on 3 Workstations:
> all 3 Workstation running with Windows 10 (Pro/64bit/build 1703)
> on all 3 Workstations 3ds max 2017 and 2018 is installed
> all 3 Workstations have the same GPU (Nvidia GTX 1070)
> one Workstation got a Intel 7700K CPU - the other both are Ryzen 1700
and now the problem:
If i use the BodyObject-Utility on both Ryzen Workstation to adjust several selected BodyObjects (imported from a step-file), 3ds max 2017 and 2018 crash without any Error-Message. With the Intel Workstation everything runs as expected.
To fix the problem, I?ve tried the following things:
* reinstall new versions of c++ redistributable
* reinstall 3ds max (both version) with different updates installed
* reinstall gpu drivers and use different versions
* reinstall windows 10 and use early builds
* use different bios versions
* use different gpus
... and nothing helped!
I would be grateful for any advice/confirmation/negation.. anything!
Cheers!
Cheers!
