Light Select and VraySun
  • Light Select and VraySun
    Hi, im testing a scene to comp it back to beauty from light select elements. I dont know if thats the proper behavior, but vray sun, doesnt include the vraysky gi. Therefore i had to use vraysky as a map in a dome light instead of the default environment (and make an extra light select element with that), and problem is solved beauty pass is exactly same when reconstructed from light select passes.
    But... my render time doubled Is there a work around on that?
    Thanks
    www.yellimages.com
    I guess we could add an option to include the environment contribution to a light select element. Would that work?
      It would be awesome, and i think it would be only needed for vraysun Light select is the most welcome addition in the latest version in my opinion!
      Keep up the good work!
      www.yellimages.com
        Very good to know!
          A bit off topic but I'm curious did render times really double when using dome light instead of environment map? I though dome lights were better and faster to render?
          Aleksandar Mitov
          www.renarvisuals.com
          office@renarvisuals.com
          AMD Ryzen 9 9950X 16-core
          96GB DDR5
            Yep, that was the reason in this scene.I never knew that dome is supposed to be faster though. Thats why on the first place i preferred sun than an HDR.
            www.yellimages.com
              In some scenes with just VRaySky and VRaySun, using only the environment may be faster.
                I dont know if i should open a new thread, but today the light select stop functioning proper. Its the same scene, same setup, i send it to backburner and noticed some crazy fireflies/pixels. The burn pixel pattern was same in all my light select passes.
                I attach image, will re assign light select and if issue keeps up i ll send scene to support. thanks
                www.yellimages.com
                  Ok, a scene will be appreciated very much.
                    Thank u Vlado.
                    https://www.dropbox.com/s/g3x9z99p1t...ENDER.zip?dl=0
                    I suspect there is something with the exposures, but the weird thing is that this scene last night was fine. Today this the very moment i sent it for render. Thanks
                    www.yellimages.com
                      Vlado any news? It could help me tones if could solve this issue in order to decide how i should composite.
                      www.yellimages.com
                        Fyi, noticing the same issue on other scenes. Seems like alsurface shader doesnt play well with this feature or i ve done something terribly wrong? thanks
                        www.yellimages.com
                          Guys, any updates plz? I m so sad i couldnt put it in production after all thanks
                          www.yellimages.com
                            Hey Vlado, i guess this is not ready yet? Just checked on 3.60.03 and didnt find it. cheers
                            www.yellimages.com
