Aerial perspective sharp horizon line and no alpha
  • Aerial perspective sharp horizon line and no alpha
    Hi, when i use aerial and i check affect env rays, i have no alpha channel in my objects. How do i solve this?
    Also, the vray sky gives me a sharp line at the horizon, how can i remove this?
    thanks
    www.yellimages.com
    When using the option Affect Environment Rays it is expected to have these results in the Alpha channel. If you like you could make another pass just for the Alpha without the Aerial Perspective effect.
    As for the "sharp line at the horizon" for the V-Ray Sky you could increase the blend angle of the map to have smoother transition.
    Nikolay Kusht | chaos.com
    Team Lead, 3D Support | contact us
      Thanks, well i see the sky fine and not sharp. When i add the aerial gets sharp. And the angle doesnt work. Besides that how would i make a pass only for alpha on same scene? thanks
      www.yellimages.com
        Can I ask what plugin are all the symbols of the left from the coloured ones?
          You could make new render without the Aerial Perspective effect and use its Alpha.
          Are you asking about PhoenixFD? This is our all-in one solution for fluid dynamics simulations.
          You could find more information here:
          https://www.chaosgroup.com/phoenix-fd/3ds-max
          https://docs.chaosgroup.com/display/...ckStart+Guides
            Hello,, i'm a facing a similar issue while using vray aerial perspective. Is there a way that the alpha wont be be modified by this function ? Or could you add an option in future release to ignore alpha ?
            Regards,
            zero-K
              Yes, please add this option
                I'm also facing this issue !! would be really helpfull if this was implemented... Many thanks in advance !
