Hello, sometimes i use this trick to cheat reflections. But i noticed that it works only when i m on exterior shots. Even if i use a dome with hdr outside, it seems that dome overrides my fake environment reflections.
Have u seen this behavior before? If its the expected one, i d suggest there should be a priority in this slot so the object understands which reflection should use or even simpler, always use the map in there once there is a map. I dont know if i explain this correct
cheers
