Wrapped diffuse or Half Lambert
  • Wrapped diffuse or Half Lambert
    Hi
    Is there a way to make use of the so called Wrapped Diffuse or Half Lambert shading/lightning technique within Vray for max?
    That is to multiply the dot product of the light normal and surface normal to strech the shading over the light terminator on a surface.
    Effectivly faking a subsurface kind of look.
    I fully understand that this is not plausible shading in any way but I'm looking for it to be able to recreate the same kind of look
    that I get with this cheat on my cartoony clouds within a realtime engine.
    Could this be possible in Vray if I learn OSL or is that shading language weighted towards physically plausible also?
    Can you show me the look you are going for?
      Many Thanks for the really quickresponse and for a wonderful product!
      Now I feel a bit stupid for asking such a weird question since looking at the result that I try to emulate
      it might just be a simple separate lightingsetup for the clouds that is needed.
      However here is a very crude setup of the look I'm after. Left cloud and sphere has a wrapped diffuse shader applied and the right ones have basic standard realtime shader.
      (didn't get the shadowmaps to get the right transparency for this test)
      Best regards
      Lars
