Many Vray Lights VS Scattered Poly Mesh Light? Efficiency?
  • Many Vray Lights VS Scattered Poly Mesh Light? Efficiency?
    I have a scene where I need to add many sources of small lights. Is there a method that is more efficient than others?
    Option A: Use many instanced area lights.
    Option B: Scatter my light emitting planes thru the scene and use a mesh light. All connected together (or into color groups)
    Option C: ??
    Increasing cutoff threshold will help. Anything else?
    John Rouse - Lead VFX Guy
    http://www.johnrouse.net
    Los Angeles, California
    You may have to do your own R&D to test that.
    I often get great feedback here but also there are times when I realise that I have to do my own R&D.
    If you already have a complex scene, then you could map out a to do list in order to methodically test shit .
      many lights. period. o lot of optimisations available. mesh light is simply VRayLightMtl.
      Marcin Piotrowski
      youtube
      CGI OCIO config 04
        Also how many of them need to be actual light sources VS a plane with vraylightmtl for visual effect
          Many lights will probably be better.
            Update: Vray area lights worked very well. I have 1300 lights in the scene and probably at least 800 on screen/casting range. No real dramatically unexpected performance hit. Scene looks really nice. Thanks
              Not true, a Vray mesh light, has way more control than a simple vraylightmtl does
