Is there any way to blend between two different pieces of geometry that intersect ?
  • Is there any way to blend between two different pieces of geometry that intersect ?
    So, for exmaple, a rock on the ground that slightly intersects. The hard edges of intersection are a problem so is there a way to blend at render time to make it look like the rock and ground are part of the same geometry?
    Regards
    Steve
    My Portfolio
    Depending on the geometry you could try with a VrayEdgeTex in the bump and uncheck "Consider same object only". I don't know if they have to share the same material though...
      Maybe some of the techniques here could be re appropriated ?
      http://polycount.com/discussion/1811...rs-battlefront
      I have been meaning to try and duplicate that in vray for a little while now.
        Isn`t that what VrayDistanceTex is for ? Not tried it but always assumed.
          Thanks Neilg! That't exactly what I was looking for
          Regards
          Steve
          My Portfolio
            Actually, that link has the correct processes for UE4 but not sure how to apply it to vray. I'll need to research some more. Maybe we could work this out between us?
            Regards
            Steve
            My Portfolio
              I think you may be right AnthonyH. I guess you would apply the distance texture to the plane and then add all the rocks? I'll give this a go Monday.
              Regards
              Steve
              My Portfolio
                So it looks like vertex normals are the answer to this effect. I guess the normals need to coincide at the seams for this to work. I wouldn't even know where to begin...
                Regards
                Steve
                My Portfolio
                  Well, it seems it's actually fairly straightforward. VrayEdgeTex in bump as Undersky said and then vraydistancetex in the diffuse to blend the colours. It works ! Thanks guys.
                  Regards
                  Steve
                  My Portfolio
                    Im not sure I understand the workflow here...has anyone managed to get this to work and and explain it again?
                    Website
                    https://mangobeard.com/
                    Behance
                    https://www.behance.net/seandunderdale
