1.46.10 Simple Benchmark
  • #31
    sounds cool.. Any legitimate reason to recommend that anyone head over and try it? I mean are you just horsing around or are you using it for a specific reason?
    • #32
      Yeah does windows run a lot faster and more efficient with xp64.. ?.. i geuss no apps are going to run any faster until they are 64 bit.
      Natty
      http://www.rendertime.co.uk
      • #33
        Hi everyone, just thought i would let you all know that after updating the Bios on my laptop I managed to get the rendertime of this benchmark file from 51mins to a blazing 33mins 48.1secs!!!!
        If anyone has any thoughts on why this would happen please let me know. I am not complaining, I am very happy with the outcome
        Chris Jackson
        Shiftmedia
        www.shiftmedia.sydney
        • #34
          1289 is available for the public preview now
          Eric Boer
          Dev
          • #35
            1289 of Win2k3 server is available, I haven't been able to find XP on the Microsoft site.
            Moving to XP64 has the advantage of system processes actually running at 64bit instead of 32bit - so the processor is emulating less right?
            And the memory...say goodbye to the /3g switch! the pagefile can get up to some ungodly size like 128 TB
            Oh and viruses, because of the rewrite of drivers and everything else in the core of Windows, most viruses need to be rewritten for the 64bit system structure from what I understand.
            But the main reason for me using it is so that I'm ready for 64bit apps when they arrive, extended available memory size, and that it seems very stupid to be running a 32bit OS when your processor is fully 64bit.
            • #36
              Here's the link http://www.microsoft.com/windowsxp/6...n/upgrade.mspx
              the iso is named w2k3sp1_1289_usa_x64fre_pro but it is XP64 pro.
              But if you still don't want to believe me then fine :P
              Eric Boer
              Dev
              • #37
                Hi everybody,
                Rendering while trying to use AutoCAD and other programs...
                15min 9.0s here.
                Later will try to leave it just rendering to see the impact on time.
                Specs:
                Dell Precision 360 P4EE 3.2Ghz 2Gb RAM
                Win XP SP1
                regards,
                Joao.
                • #38
                  Ok, I've just rendered while was out for lunch, and time was:
                  14m 25.6seconds
                  Same specs as above.
                  regards,
                  Joao.
                  • #39
                    Here are my results:
                    Dell Precision 650
                    Dual Xeon 2.66 (533 mhz bus) HT Disabled
                    2 gigs Ram
                    Win 2K SP 4
                    If I turn on DR and use our two slaves I get this:
                    The are both identical:
                    Dual Xeon 2.8 (533 mhz) HT enabled
                    2 gigs Ram
                    Win XP SP2
                    Chris
                    The Revitlution
                    • #40
                      Wow hyperthreading just rocks. Nice work with the EE's Twinxel.
                      LunarStudio Architectural Renderings
                      HDRSource HDR & sIBL Libraries
                      Lunarlog - LunarStudio and HDRSource Blog
                      • #41
                        10 min 5 seconds here.
                        dual XEON 2.8GHz wih HT enabled on a supermicro mobo
                        2GB ram.
                        • #42
                          3m52.4s with DR with x5 Dual Xeon 3.06GHz + 2GB Dual-DDR333 in max 6.
                          9m32.5s with just one machine.
                          Simon Askham - http://www.supercreative3d.com Rendering with Threadripper 2990WX Asus Prime X399 36GB DDR4
                          • #43
                            ...that's just wrong
                            • #44
                              Has anyone got any bigger bench mark tests?
                              • #45
                                The hyperthreaded dual Xeons seems just about the same speed as dual Opterons. So I wouldn't go too googoo-gaga over them.
                                Notice everything in the 3-5min range was done with DR.
