Hi all,
I have been trying to achieve this in Vray but couldn't. In Arnold, I can achieve this by assigning an aiShadowMatte shader to a ground geometry. In the aiShadowMatte, specify using "background color" and plug a projected plate image. In a single render, I got a ground that returns projected plate color, which is not affected by scene lighting, and the shadows. (example below)![Arnold shadow matte.jpg Click image for larger version Name: Arnold shadow matte.jpg Views: 2 Size: 131.8 KB ID: 985799](filedata/fetch?id=985799&d=1604765289)
In Vray, I've tried assigning VrayMtlWrapper to the ground geometry. But as I use a VrayLightMtl with a projected plate as the Base Material, it cannot catch the shadow. And as I turn on Matte Surface (Alpha Contribution -1, Shadows On, Affect Alpah On), the shadow is in the alpha channel but not in RGB. Also, the whole ground is black, which is the environment color.![Vray shadow catch 01.jpg Click image for larger version Name: Vray shadow catch 01.jpg Views: 2 Size: 32.2 KB ID: 985800](filedata/fetch?id=985800&d=1670186997)
![Vray shadow catch 02.jpg Click image for larger version Name: Vray shadow catch 02.jpg Views: 2 Size: 38.6 KB ID: 985801](filedata/fetch?id=985801&d=1670186997)
Will be happy to learn a way, either object property-based or shader-based setup to achieve this in Vray.
If this is not achievable, please consider this as a feature request. I'll be more than happy to add a thread in the Wishlist subforum.
To John O, if you came across this thread, I really don't want to bake the lighting. It works, but I can't then change scene lighting without re-bake.![smile](https://forums.chaos.com/core/images/smilies/smile.gif)
cheers,
Jason
cheers,
Jason
