Plastic material using VrayEdgesTex in a composite map as bump map
  • Plastic material using VrayEdgesTex in a composite map as bump map
    Hi guys,
    I'm trying to make a plastic material with multiple bump maps, and an VrayEdgesTex to create bevels. But I can't seem to do that with GPU.
    I can use the edge map in a composite map if it goes in the diffuse, but not if it goes in the bump. Unless I switch to CPU.
    Any ideas? (besides switching to CPU, as keeping everything as GPU is part of the test for me )
    /Jonas
    Sample scene:
    https://www.dropbox.com/s/m37o2t4l4h...gemap.max?dl=1
    Jonas Ussing, VFX supervisor in Copenhagen, Denmark
    I had this problem before. Couldn't solve it . Would be great if there is a solution .
    www.AddYourLight.com
      Do you need this?
      Best,
      Blago.
      V-Ray fan.
      Looking busy around GPUs ...
      RTX ON
        If this equivalent to round edges? Cant be, right?
          It is (rounded edges + procedural bump). You have edges tex as bump map. This is the way it works in V-Ray GPU since 3.5.
          Best,
          Blago.
          V-Ray fan.
          RTX ON
            Awesome, thanks! That does the job.
            /Jonas
              Best,
              Blago.
              my bad, I was seeing it as plugged into the IOR slot. lol sorry
                any idea how I can combine vrayedges with some noise to make the bump material less even? Trying with vraycomptex but it doesnt seem to blend..neither does composite..
                  Just as I have showed?
                  Bets,
                  Blago.
                  V-Ray fan.
                  RTX ON
                    I don't understand.
                    how would I use that to combine edgetex rounded corners with a noise map?
                      Probalby I don't get the question, but you can use the noise tex where I have used composite?
                      Best,
                      Blago.
                      V-Ray fan.
                      RTX ON
                        I'm trying to do this
                        http://www.peterguthrie.net/blog/200...illet-tutorial
                        He is using general edge Tex but I only want the rough irregular bump at the corners, not all edges.
                        Is that possible somehow?
                          As I have showed, it will blend the bump map that you add with the rounded edges. Not sure how to make the bump map affect only aroudn edges though.
                          Best,
                          Blago.
                          V-Ray fan.
                          RTX ON
                            That's what I'm after. I don't need perfect round edges, I want them rugged. I don't understand why edgetex round corners can't be combined..
                              It's a special texture that is evaluated differently from regular bump maps. It's on the "to do" list to make the radius parameter mappable, which should help to break the straight edges a bit. We also plan to add an additional bump slot inside the edges texture. I can do it in a couple of days for V-Ray Next, if you are in a hurry.
