what are these? (fireflies)
  • what are these? (fireflies)
    since I switched to vray next I get such bright points in my renderings... https://c2n.me/3UQKul4.png
    I have no other materials in the scene, nor no material on objects.
    best hregards
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    Send me the scene please.
    Peter Matanov
    Chaos
      well, these extreme white or colorful spots are really annoying! also because the lens effect will create an extreme flare on these spots, so the whole render element is unusable...
      Pixelschmiede GmbH
        Did you get a solution as I am having the same issue, thanks
          no, unfortunately not. I got a response from the support, that this IS a bug... so they are working on it, I hope. ​​​​​​​
          Pixelschmiede GmbH
            Ah...Thanks for letting me know
            I was hoping it wasn't something random that I've been using in my scenes.
            Let's hope there's a fix soon...especially after the costly upgrade!
              Getting these as well (VRay Next Update 1.1)
              Annoyingly only on 1 frame and only via Maya Batch (do not appear locally in VFB)
                Could it be a denoiser issue?
                Bobby Parker
                www.bobby-parker.com
                e-mail: info@bobby-parker.com
                phone: 2188206812
                My current hardware setup:
                • Ryzen 9 5900x CPU
                • 128gb Vengeance RGB Pro RAM
                • NVIDIA GeForce RTX 4090 X2
                • ​Windows 11 Pro
                  Not using denoiser for this project.
                    Can you send me the scene?
                    Peter Matanov
                    Chaos
                      make your sun invisible and turn off specular on the sun.
                      WerT
                      www.dvstudios.com.au
