Is it possible to make textures in a VrayHDRI map inside a VraylightMtl show in viewport? It doesn't seem to work even if I choose "show realistic material in viewport" from the Classic material editor. Bitmap works fine. Any ideas?
Can't see texture in viewport if they are in a VrayHDRI map inside a VraylightMtl
Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
AMD Ryzen 7950X 16-core | 64GB DDR5 RAM 6400 Mbps | MSI GeForce RTX 3090 Suprim X 24GB (rendering) | GeForce GTX 1080 Ti FE 11GB (display) | GPU Driver 546.01 | NVMe SSD Samsung 980 Pro 1TB | Win 10 Pro x64 22H2Tags: None
Thanks for the input. I found a workaround. I have put the VraylightMtl in a Shell material and in the Baked Material slot I have put a standard material in which I plug the same diffuse and opacity textures as the ones used in the VraylightMtl. Then I just select the Standard material and click "Show shaded material in viewport". Voila!Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
When is this going to be fixed please?
I cant see any textures when i use VrayHDRI map to load bitmaps for my materials?
EDIT:
looks like its MAX thing....Last edited by PIXELBOX_SRO; 19-10-2018, 12:36 AM.Martin
http://www.pixelbox.cz
