warning: Material
  • warning: Material
    I am getting those new unlocked highlight and reflection glossiness warnings, however, now they are in the thousands. My current scene is showing 5999 of them. Should I just ignore these or is there something I need to do?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    i have the same message, normally this happen with old scene
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 1 [7.00.05 build 32872]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
      My concerns are more that I don't have the ability any more to have different glossy and highlight values. I still use a lot of point light (in most cases spots) for better performance. Now I have to use a blend material to have a proper high light without glossy reflections. Yes, I know that's not physical correct,
      but please give us the freedom to be creative. I would have liked that it would be possible to have the possibility to edit even the high light strength independently.
      www.dk-vision.de
        As Vlado stated this would break the current optimization they did to the sampler: https://forums.chaosgroup.com/forum/...he-hglossiness
        So in other words or as far as I understand, there's no way back. What would be handy for you guys is a script or something that converts all these materials to a blend material with the same look, but I don't think that these 'creative' materials are easily put into some equation or whatnot to mimic the same look.
        A.
        www.digitaltwins.be
          It would also help to have a script to change the material that the error is fixed, even if the "manual highlight" is than disabled and because we can't disable the independent highlight any more in vray next!
          www.dk-vision.de
            Hi, you can use the V-Ray scene converter with the default settings to get rid of the warnings.
            Martin Minev | chaos.com
