V-Ray uses only 50% of the CPU while rendering? This time 3ds max 32 thread system
  • V-Ray uses only 50% of the CPU while rendering? This time 3ds max 32 thread system
    As is started with Vray next a few weeks ago i also discountered the laggy behavior bug while rendering.
    I did create the environment variable and set it to 31 threads which worked out fine.
    But now i discovered that my whole machine just uses approx. 56% cpu power while rendering.
    Is this the way it should be or is there something wrong here?
    OLIKA
    www.olika.de
    Is it the same 50% utilization with both the Progressive and the Bucket sampler?
    Miroslav Ivanov
    Chaos Cosmos
      Hi Miro ,
      good idea, tested it right now and seems exactly the same
      OLIKA
      www.olika.de
        Hello,
        From the screen shot it looks like you have 56 threads so if you want to render with one thread less then Max you should set the env. variable to 55 and not 31.
        Yavor
        Yavor Rubenov
        V-Ray for 3ds Max developer
          lol! ...can i delete the thread cause it`s so embarrassing
          this forum is so priceless when i sometimes just not be able to count 2+2!
          thanks yavor.rubenov helping sort my brain
          all in full throttle mode again great!
          Click image for larger version  Name:	cp2..jpg Views:	1 Size:	230.4 KB ID:	1007880
          OLIKA
          www.olika.de
            Glad that helped
            Yavor Rubenov
