Computer Freeze
  • Computer Freeze
    Okay, I am having a hard time with computer freeze. V-Ray continues to render, but the screen, mouse, and everything else is frozen. I can't CTRL+ALT+DEL or anything. I just finished one view and it froze for 39 minutes, 1/2 way through the render and then poof, it's done. I have MAX set to low-priority, but it doesn't matter. This has been happening ever since NEXT.
    MAX 2019
    Windows 10
    VRay NEXT
    Is there anything I can do? No displacement or anything else complicated in the scene.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    I ended up hard rebooting my PC since it was frozen for about an hour, and the second time around there wasn't any freezing.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      if its such a bad issue try working with HT off. (HT - Hyprethreading.) I know its a bummer but it might be better for you.
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
        You know, when DELL tries to optimize my machine for 3DS MAX it does turn it off. I'll have to see what happens.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Really? I thought it can only be done in bios?
          Dmitry Vinnik
          ShowReel:
            I can turn it off/on with the application
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Did you try the environment variable VRAYNUMTHREADS Bobby???
              I had these freezes and it helped.
              Martin
              http://www.pixelbox.cz
                I already have more threads than V-Ray sees, but let me see if that helps.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  I have a System variable VRAY_USE_THREAD_AFFINITY and the Value is 1. I have 2 processors, each with 18 cores and with multithreading, I have 72 cores. What should I set this at?
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Vlado wrote about this some time ago but there are different threads about it and some are quite misleading about what to do.
                    you need to run environment variable for your windows user (or whole system up to you) and make a new general environment variable VRAYNUMTHREADS=X where X is all your THREADS minus lets say 1-2
                    Save it and youre done you wont get it anymore and if yes, raise the number of threads you deduct. So if you have 36 threads, you shoud type VRAYNUMTHREADS=34
                    try this
                    Martin
                      Precisely an example of a discussion Lele and I had the other day. If you are a new reader and search for a topic you'll get ten different people to tell you ten different ways to do something; you'll go batty!
                      Does this include multithreading? I have 36 cores, but 72 when multithreading is on, which it is. So, in my case would it be?
                      VRAYNUMTHREADS=34
                      or
                      VRAYNUMTHREADS=70
                      My only other question is V-Ray already tells me that I have more cores that V-Ray will use, so I should already have a few left over, no?
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        yep you should have a value 70.
                        However its weird that vray is not using only those 64 threads allowed.
                        strange
                        Martin
                          Yeah, I get the warning that it won't use more than 70 cores
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Sure bur if you dont use more than 64 and still have 8 left then why the freezes. It doesnt make sense.
                            Martin
                              Yeah, changing it to 70 cores didn't make a difference, it's still freezing.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
