Im getting really unusual results when using vraynormal map. Its seems like it can't deal with chamfers or something. I get the same result when using vray next gpu or cpu (using max 201
First image below is a normal map going straight into the bump slot. Results are as expected.
Second image is the same normal map going through the vraynormal map and then into the bump slot. Vray normal map parameters at default.
Is this a bug or am I doing something wrong? Anyone else getting this issue?
