Vray normal map broken
  • Vray normal map broken
    Im getting really unusual results when using vraynormal map. Its seems like it can't deal with chamfers or something. I get the same result when using vray next gpu or cpu (using max 201.
    First image below is a normal map going straight into the bump slot. Results are as expected.
    Second image is the same normal map going through the vraynormal map and then into the bump slot. Vray normal map parameters at default.
    Is this a bug or am I doing something wrong? Anyone else getting this issue?
Name:	normal straight in.jpg
Name:	vray normal map.jpg
    Nick Martin
    ScreenAge - 3D Visualisation
    www.screenage.com.au
    Please share a screenshot of the material setup or even better - send me the scene.
    Peter Matanov
    Chaos
      If you're working in LWF (gamma 2.2) :
      Check "Override gamma : 1.0" in the bitmap loader of the map
      If it's loaded in 2.2, you might have 0-127 value in the blue channel, leading to artifacts (blue channel cannot leave 128-255 range)
      Philippe Steels
      Pixelab - Blog - Flickr
        Hi Guys, yep its the bitmap loader settings... if set to override gamma 1.0 if works as expected.
        When loading normal, bump, displacement, specular, glossy maps it seems the same rule applies. This info often gets overlooked I think.
        Nick Martin
          When loading normal maps, always as gamma 1.0. And normal maps from lots of sites these days need to flip green channel.
          AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
          2D | 3D | web | video
          jiri.matys@gmail.com
          https://gumroad.com/jirimatys
          https://www.artstation.com/jiri_matys
          https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
          https://www.instagram.com/jiri.matys_cgi/
          https://www.behance.net/Jiri_Matys
          https://cz.linkedin.com/in/jiří-matys-195a41a0
