So I experienced some issues with DR and slow renders and I think it is caused by the KB4343909 update.
Render slaves will refuse to connect no matter what scene I use.. (can't think of anything simpler then a teapot and vraylight... still crashes DR)
Also not sure what happened, but local rendering went extra slow.. from 15 seconds of IR pass to 7 minutes..
I did a system image restore to all machines (from before this update) and everything seemed to work again as before.
But as soon as the update kicked in - everything is broken all over again
Anyone else experienced it?
-edit-
Forget to add a little bit of context.
WS is an AMD Threadripper 1950x@4.0ghz, 32GB Ram, GTX 1080, Windows 10 Pro, 3dsmax 2016sp4 and latest Vray 3.6.
The 2nd WS is exactly the same.
The Render slaves are i7 6700, 32GB Ram, Windows 10 Pro, 3dsmax 2016sp4 and latest Vray 3.6.
I got some more progress today.
While the render slaves will not connect at all, I got the 2nd WS connect via DR. Problem is it renders only black buckets.
And once again - if the update removed everything is good again.
Progress next comment
-edit-
