What causes the light cache to get stuck? Everything was moving fine and I removed everything that might have caused it, however, things still get stuck.
Building light cache
1 PhotoBobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
Yep so I have been killing MAX every time I try something to fix it that doesn't work. I tried BF+BF and the rendering just stuck at a black screen.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I converted the scene a few times, which did nothing. I'll try converting to hdri.Last edited by glorybound; 15-09-2018, 04:18 PM.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Did it help? My rendering finished without any further hickups, but I'm not sure if converting to vray-HDRI maps did the trick, or if it was because of lowering the number of hairs on a few hair and fur objects. My machines has a ton of ram though, so I don't think it was running out of memory (less than half was used)
Mine just crashed to desktop while convertingBobby Parker
phone: 2188206812
- Windows 11 Pro
No, not your fault. I tried converting again, it worked and I hit render, at which time it crashed again. The frustrating as heck part is this is the third house, which is using the exact same assets as the first two. The first two rendered fine, but I have spent the last 4 hours trying to render this one out.
1 PhotoBobby Parker
phone: 2188206812
- Windows 11 Pro
Things are going from bad to worse. Now if I open the model it crashes.
1 PhotoBobby Parker
phone: 2188206812
- Windows 11 Pro
Solved. Raytrace material that the UMC took care of.Bobby Parker
phone: 2188206812
- Windows 11 Pro
That was an old project that they changed a few things. The siding was done with Railclone, however, I had to do it all over because Railclone changed something since I built that model; all the siding failed when I opened the old scene.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Yes, it is tedious and sometimes finicky.Bobby Parker
phone: 2188206812
- Windows 11 Pro
