Vray ADV / RT Exposure problem
  • Vray ADV / RT Exposure problem
    Hy,
    image says it all!
    Overexposure in RT (Activeshade) normal exposure in ADV (Production), why's that?
    Thanks
    Greets Phil
    WS
    DUAL E5-2683 V3 28c/56t @2,6Ghz
    64GB Ram
    ASUS ROG STRIX OC 1080ti
    PALIT SUPER JETSTREAM 780ti
    Node
    I7 2600K @4,40GHZ,
    32GB RAM
    Hello,
    What camera are you using in this scene (if any) ?
    Also - looking at your signature - you have nVidia cards but on your screen shot you are using OpenCL? CUDA will give much better results on nVidia cards.
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      I‘m using max physical cam.
      thanks for the hint with the opencl, i thought with my xeons the performance will be better...?
      Greets Phil
      WS
      64GB Ram
      Node
      I7 2600K @4,40GHZ,
      32GB RAM
        In V-Ray RT 3.6 we supported only the Physical Camera Exposure control together with the Max Physical Camera - so without it you get no exposure at all.
        If you want to use your CPUs together with the nVidia video cards there is a device called "c++/cpu" available in the device selector - if enabled it allows you to run the CUDA render on your cpus too.
        Yavor Rubenov
          Yes im doing that! See my post
          Greets Phil
          WS
          64GB Ram
          Node
          I7 2600K @4,40GHZ,
          32GB RAM
            In the screen shot I see the "V-Ray Exposure Control" which was not supported. You have to use the "Physical Camera Exposure control" - the one that goes together with the Max Physical Camera.
            Yavor Rubenov
              ahhh, ok thx. why is this not supported? it would be a super handy solution also for rt, or am i wrong?
              Greets Phil
              WS
              64GB Ram
              Node
              I7 2600K @4,40GHZ,
              32GB RAM
                The idea was to only use the Autodesk camera and exposure control together. Initially we even hid the V-Ray Exposure control and camera altogether but later on brought back the exposure control as it was helpful for non camera viewports.
                In V-Ray Next we brought back the VRayPhysicalCamera too and with it we took care of cases like yours..
                Yavor Rubenov
                  thanks yavor for your answers, it seems i should move on to next......
                  have a nice day!
                  Greets Phil
                  WS
                  64GB Ram
                  Node
                  I7 2600K @4,40GHZ,
                  32GB RAM
