"3dsmax adapter error: autodesk 21.2 reported error: [vray] error getting library description Program Files\autodesk\3dsmax 2019\vray_http_client.dll"
I saw that someone got this error before, and they solved it by making sure they had an internet connection. I have checked that and it's not the problem.
I'm using 3dsmax 2019.2, and vray next and just rendering a simple test file using backburner to a server (a new one I'm setting up). The scene renders fine on the main computer (and on a different server, I just tested). It also renders fine using 3ds max 2017 with vray 3.6. I have reinstalled vray next once just in case, but that hasn't made a difference. I hesitate opening max on the server computer to test it as it's only used for rendering, and thus not authorized, and I don't want to use up my 30 day window, unless I have to (assuming Autodesk still gives you that). Any ideas?
