Vraydistancetex problem
  • Vraydistancetex problem
    I'm using a particle flow system that moves across a plane to generate a ship wake. I'm using distancetex to detect the particles close to the plane to drive an opacity map for the coat layer on a vrayblend shader.
    The problem is that if I make changes to the particle flow system, to see any changes appear in render I need to remove that system from the Vraydistancetex list and re-add it.
    I'm using Vray 3.60.04 and Max 2018 SP4
    Regards
    Steve
    My Portfolio
    Hello,
    Could you send the scene to support@chaosgroup.com just to be sure that I have understood you correctly?
    Philip
    Philip Shounev
    QA department
    Chaos
    philip.shounev@chaos.com
      Hi there. I've sent the stripped down version via wetransfer. It's very odd. The render of the distance tex sometimes works and sometimes doesn't. I also just tested it again and the distance tex mask wasn't lining up with the particles...the mask seems to be delayed behind the particle emission. I also have to disconnect the particle nodes in particle view for the distancetex mask to become active. Other times the distancetex mask just doesn't seem to render.
      Regards
      Steve
      My Portfolio
        Hi. Have you had any luck with the scene I sent ?
        Regards
        Steve
        My Portfolio
          Hi, could you please provide us the ticket number or the e-mail you send it from.
          Martin Minev | chaos.com
            Hi. The ticket number is: 384-964-699
            Regards
            Steve
            My Portfolio
              Hello,
              Particles loaded as distancetex objects are not supported yet. So, it has been added as a new feature request to our bug tracking system with ID: VMAX-7774.
              However, there is a workaround for that. You can try using 3ds Max Mesher from compound objects menu which will convert particle systems into meshes without losing the animation sequence. Then the next step is to set
              visibility of the particle meshes to 0 (from object properties menu) and add those freshly created meshes to the distancetex list.
              Philip
              Philip Shounev
              QA department
              Chaos
                ok thanks. I'll give that a go
                Regards
                Steve
                My Portfolio
                  Thanks. This worked well
                  Regards
                  Steve
                  My Portfolio
