Lens effects
  • Lens effects
    Not sure why, but Lens effect never works for. i was hoping with the new vray, I would be as easy as enabling render, but nothing. What's the trick?
    Vincent Jaramillo
    Smithgroup
    301 Battery Street
    San Francisco, Ca 94111
    There is no trick. Just turn them on.
    Peter Matanov
    Chaos
      I've turned it on and no results. Is it based on vraylights, does it look for emissive materials to generate glare?
      Vincent Jaramillo
      Smithgroup
      301 Battery Street
        It's based on pixel values. Can you send me a scene? It will be way faster than guessing
        Peter Matanov
        Chaos
          Are you using Exponential color mapping or Reinhard with low Burn value? I'm guessing this since I saw your other thread with the washed out rendering where you said you didn't use sRGB and linear workflow. If you do use Exponential or Reinhard with low Burn value, your pixel intensity values will be way down and lens effects rely on pixel values larger than 1 to work as expected. Try switching to Reinhard with Multiplier and Burn values set to 1 or to Linear Multiply with Dark and Bright multipliers of 1. You'll also need to switch to linear workflow. I commented in your other thread how to do that.
          Aleksandar Mitov
          www.renarvisuals.com
          office@renarvisuals.com
          AMD Ryzen 9 9950X 16-core
          96GB DDR5
            Sure...How do I get it to you?
            Vincent Jaramillo
            Smithgroup
            301 Battery Street
              It's a sign that your lighting is off. Crank your lights to real-world values and expose with your camera, again with real-world values.
              Bobby Parker
              www.bobby-parker.com
              e-mail: info@bobby-parker.com
              phone: 2188206812
              My current hardware setup:
              • Ryzen 9 5900x CPU
              • 128gb Vengeance RGB Pro RAM
              • NVIDIA GeForce RTX 4090 X2
              • ​Windows 11 Pro
                My mail is in the signature. You can also check what Alex_M is proposing.
                Peter Matanov
                Chaos
                  I think it would be a good idea to remove the color mapping values entirely from the interface. It seems this is still a huge source for user errors after all these years. All the stuff that can be achieved with these settings can easily be done inside the VFB.
                    Ha...It's always good to re-evaluate ones process. Changing my burn value from .08 to 1 made the difference. Getting the lens flares.
                    Vincent Jaramillo
                    Smithgroup
                    301 Battery Street
                      The floor is full of denoising artifcats, and it is a mushy mess. Are these final images you are delivering to your client?
                        Glad you noticed. This was a test file. I've posted the issue with denoiser artifacts. Never had this issue before updating to VrayNext.
                        Vincent Jaramillo
                        Smithgroup
                        301 Battery Street
                          The denoiser is exactly the same in Next as it was in 3.6 and still had the same issues. I have some plans to improve it for Update 2.
                            Never used 3.6 We went straight from 3.5.4 to Next.
                            Vincent Jaramillo
                            Smithgroup
                            301 Battery Street
