Not sure why, but Lens effect never works for. i was hoping with the new vray, I would be as easy as enabling render, but nothing. What's the trick?
Lens effects
Are you using Exponential color mapping or Reinhard with low Burn value? I'm guessing this since I saw your other thread with the washed out rendering where you said you didn't use sRGB and linear workflow. If you do use Exponential or Reinhard with low Burn value, your pixel intensity values will be way down and lens effects rely on pixel values larger than 1 to work as expected. Try switching to Reinhard with Multiplier and Burn values set to 1 or to Linear Multiply with Dark and Bright multipliers of 1. You'll also need to switch to linear workflow. I commented in your other thread how to do that.Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
AMD Ryzen 7950X 16-core | 64GB DDR5 RAM 6400 Mbps | MSI GeForce RTX 3090 Suprim X 24GB (rendering) | GeForce GTX 1080 Ti FE 11GB (display) | GPU Driver 546.01 | NVMe SSD Samsung 980 Pro 1TB | Win 10 Pro x64 22H2
It's a sign that your lighting is off. Crank your lights to real-world values and expose with your camera, again with real-world values.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- ​Windows 11 Pro
Originally posted by Alex_M View PostAre you using Exponential color mapping or Reinhard with low Burn value? I'm guessing this since I saw your other thread with the washed out rendering where you said you didn't use sRGB and linear workflow. If you do use Exponential or Reinhard with low Burn value, your pixel intensity values will be way down and lens effects rely on pixel values larger than 1 to work as expected. Try switching to Reinhard with Multiplier and Burn values set to 1 or to Linear Multiply with Dark and Bright multipliers of 1. You'll also need to switch to linear workflow. I commented in your other thread how to do that.
Originally posted by vjaramillo View PostNever had this issue before updating to VrayNext.
- Likes 1
