NEXT Update 1 glass
  • NEXT Update 1 glass
    Has anything changes with reflections in the latest VRay Next? My glass is barely reflecting and nothing in my workflow has changed. My glass is a muddy dark gray. I’m talking exterior building glass.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Probably ticked something by accident. Post a max file with a cube (or teapot) with the culprit glass so we can have a look
    Kind Regards,
    Morne
      It's been the last three projects. I'll look closer on this next project.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I have few glass materials that I made long time ago and haven't touched these since then, I used them for couple of recent project and can confirm that something is different now.. Thought I was going crazy
        When I get to office will investigate more and compare to 3.6 .. will let you know how it goes
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
          Can you post an example material and example render?
          In a quick simple test I'm not seeing anything different
          Kind Regards,
          Morne
            I am making a small change to an interior I did four months ago. The interior has a pool and the water was reflective but transparent. I opened it up, made a small change to a wall and rendered. The water now has no transparency and my refraction element has nothing. Something definitely changed in Update 1. I'll post something when I get a chance.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Are you using a different HDRI for reflections in this scene?
              It was probably related to the HDRI I used for reflection override in my scene.
              I cannot reproduce this for now though..
              Muhammed Hamed
              chaos.com
                No hdri on this one. No exterior windows.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  https://forums.chaosgroup.com/forum/...-pass-behavior
                  Maybe related to your issue Bobby?
                  Kind Regards,
                  Morne
                    Yes, maybe. I'll try things without adaptive and see if it reverts back to the results I am used to. Right now, my reflective passes are useless, however, it seems like my specular compensates for it.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Thanks for sharing Morne!
                      Muhammed Hamed
                      chaos.com
