Vray denoiser - squares and blotches are ruining my render.
  • #16
    I'm tinkering with a de-speckle pass before denoising, but it's not quite where I want it to be yet. It's something that you can try on your own though - if you can take an OpenEXR file and de-speckle it in PhotoShop or something and then pass it back through the V-Ray denoiser, it might work better.
    What are you using to despeckle - please bear in mind this is for an animation, and the speckles are in the reflections (with depth of field)... I would need to despeckle all channels yes?
    Is there any way you can let me know when this is featured in the nightly builds?
    http://www.jd3d.co.uk - Vray Mentor
    • #17
      Yup, very good points, will keep them in mind.
      I'll try, but it will probably not be in time for your current project :/
      • #18
        Has there been any movement on this, it's been a couple of weeks, I've been away so it would LOVE it if there was some nightly nonsense I could try.
        Also, what are you using to despeckle? every later?
        • #19
          I actually do have something, but it's not even in the nightly builds and I'm not sure it will work for you. If you email me to vlado@chaosgroup.com with your 3ds Max version, I can get you a build to experiment with.
          • #20
            Email sent! thanks!
            • #21
              Alternatively, for those interested, i have a nuke node i could share, which removes fireflies and NaNs. (EDIT: Attached)
              Lele
              emanuele.lecchi@chaos.com
              Disclaimer:
              • #22
                Oh, that's cool very kind of you.
                Sadly I'm on After Effects... does your node strip out of all the elements pre-denoising?
                • #23
                  Not, it just checks pixels with a square kernel, and uses the average to fill in the gaps.
                  In nuke, where one decides to apply it is irrelevant, so i don't need to deal with REs within the tool (well, not for this.).
                  Does AE these days have a script node, able to run through all pixels? If so, i may be able to make one for it too.
                  Notice it only works (well, if i say so myself) with individual fireflies. Splotches may require more applications, and even then may fail (ie. i used a simple simple approach, nothing fancy.).
                  Lele
                  Disclaimer:
                  • #24
                    Just jumping in as I have exactly the same issues if I use the progressive render method. It does not happen in bucket mode at a decent sample rate (default settings work fine) and a default denoiser. That makes the progressive renderer completely useless for animations and even most stills.
