It's really Ward - how did you guess ?
red dots in glass
I have come across this, turning off the AA filter catmull-rom etc reduces the big red dot to a one pixel dot....
I also noticed that the red dots appear on shellac materials... and its funny they look green in vray frame buffer and red in max buffer.Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
well its definitely an issue with the new build, since when net rendering it was only happening on a couple of machines, turns out those ones had .15 on and the others had .14
so ive now moved all renderboxes back to .14 and no more dots.
as i mentioned earlier, this scene is hooj, so im kinda glad i didnt have to go hunting for uvw maps!
thx for all suggestions!
You can easily check for missing uvw channels by switching for a moment to the scanline renderer and trying to render the scene - it will put up a warning in this case, and a list of the problemmatic objects.
VladoI only act like I know everything, Rogers.
vlado what if my mesh has uvs and still produces red dots? I have unchecked the compatable max sahder content and it sill does it...Dmitry Vinnik
ShowReel:
If you can send me your scene at vlado@chaossw.com, I can look at what's causing it; it's hard to say right away.
tomorrow will doDmitry Vinnik
ShowReel:
Vlado i have red dots. Vray 1.46.15
Material
No changes in output chanel
Vlado wats a problem?
Very interstet result if i changed ALL material to Vraymat (button override mtl in Global switches). I have red dots again.
And Vray message raport - Material returned overbright. Its possible?
Sorry my English[img][/img]
I use Sun Light whit VrayShadows (no areashadows)
If I OFF sun - red dots dead and all ok
Uf...ok
I close file and open again. I no see red dots.
I close file and open again. I see red dots.
Its bug Vray.
Re: ...
Uf...ok
Its bug Vray.
maybe you were looking directly into your sun. you know your not supposed to look directly at the sun you might see little red spots.
hey, i dont know what is going on with those red dots, but that exist, exist... in my image, they ocurred because of the floor material, but there is nothing diferent on it than what i've been using latelly, just a tile with reflections... if i aply a white vray material at the floor, the red dots just desappear
hey vlado, i sent you the file, please, take a look and give us a feedback. i've lost a whole night render because of this new issuenatal - brazil
