I have been fighting this for days. I have a displacement, which is a gradient. I am not seeing any definition on the left side of the displacement. I am using V-Ray NEXT. I am going to try a V-Ray extra texture in post, but shouldn't I be seeing a line where there is one? The first image is how it looks and the second is the dirt pass. I am using vraydirt on the material, too, but it's not helping.
Lost detail
Lost detail
2 PhotosBobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
I am using V-Ray's default settingsBobby Parker
phone: 2188206812
- Windows 11 Pro
and I am not using denoiserBobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by PIXELBOX_SRO View Posti guess nope :-/ not in these lighting conditions unfortunatelyBobby Parker
phone: 2188206812
- Windows 11 Pro
in these situations i use a bit of dirt with negative falloff which tends to be daker than positive fallof adn use composite tex with multiply on top. You can also use some grunge map in the radius of the dirt to get uneven result.Martin
http://www.pixelbox.cz
What do you mean negative falloff? It doesn't seem to go into the negative.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Like a .005?Bobby Parker
phone: 2188206812
- Windows 11 Pro
sorry i meant distribution.
try -10, -50, -100 (sometimes high numbers produce unwanted artifacts)
Martin
Hi Bobby,
Is it supposed to be wooden planks like a cladding?
I guess so, but your wood texture should not be applied like that but rather like different boards ... I hope you know what I mean.
Anyway, it will help to get something more accurate
Anyway, I agree with Martin(Sorry for my bad english)
Yeah, but it is the whole house. Nothing worked, so I'll just use the V-Ray Dirt pass in post-production.Bobby Parker
phone: 2188206812
- Windows 11 Pro
What I've done in the past is create a blend material. My base is the Vraymtl with all it's goodies...ex. your wood. The coat is a basic black material or a darker tone of you wood. In the mask I add a vrayedgetex material. I get the outlines that can be adjusted as needed.
Vincent Jaramillo
Smithgroup
301 Battery Street
San Francisco, Ca 94111
- Likes 1
I'll give it a try next time, thanks!Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by vjaramillo View PostWhat I've done in the past is create a blend material. My base is the Vraymtl with all it's goodies...ex. your wood. The coat is a basic black material or a darker tone of you wood. In the mask I add a vrayedgetex material. I get the outlines that can be adjusted as needed.
Bobby Parker
phone: 2188206812
- Windows 11 Pro
