Fire Flies with Progressive rendering - Affect shadows
  • Fire Flies with Progressive rendering - Affect shadows
    I'm getting a lot of flickering fire flies with a leaf material I have on some Pine trees. The trees flicker like a Disney Christmas tree with flashing lights inside!
    Through a lot of trial and error I've traced this to the Refract setting, and unchecking Affect shadows this cures the problem, although the tree's don't look as good.
    For info the tree's are only flickering when they are backlit. A different camera angle which see's the tree's lit from the front results in no flickering.
    Vray Next update 1.1
    Settings:
    BF + LC
    LC at 1500
    Min. subdivs 1, Max 100
    Rendertime 17min
    Noise threshold 0.007
    Color mapping - Reinhard.
    Sub-pixel mapping ON or Off
    Clamp output 2.0 On or Off
    Pretty much everything I've tried still results in pesky fire flies to be honest, apart from the Affect shadows mentioned earlier.
    Hope this helps
    PGDesigns.co.uk
    Add different render elements and see in which one you could notice the flickering(GI, Lighting, etc.)
    Also, could you share your scene with us so we could take a look and see exactly what is going on/
    Nikolay Kusht | chaos.com
    Team Lead, 3D Support | contact us
